kkonecny
OLS regression tool help Arc Map 9.3
Discussion created by kkonecny on Jun 19, 2011
Latest reply on Jul 26, 2011 by lrosenshein-esristaff
I need some assistance with using the OLS regression tool in ArcMap 9.3.
1) I created a shape file from an excel file with XY coordinates using Arc Catalog.
2) I opened the table in arc map and added a unique field ID (=FID+1), using the field calculator.
When I select the shape file in the OLS tool window I get a red X in the upper left corner of the first field.  I am assuming the red X means there is a problem with the shape file.  If I move through the rest of the fields in the tool and click the ok or run button I get an error message with no text.
Is the shape file created correctly? Is the unique field ID created correctly?
I have attached a sample of my excel data set for anyone to test.
Any help is much appreciated.
Ken
P.S. the original data set has 10,000 observations and 80 variables.
Outcomes
