I try to create a new map document in C# with the following code and cast it to an interface, while casting to IDocument I can implicitly cast to: IDocument iDoc= new MxDocument(); however, I need explicitly cast for the following interface: IMxDocument IMxDoc = new MxDocument() as IMxDocument. Is there any particular reason that one interface can implicit cast but the other can't?
Also, from the attached OMD, how can I tell that IDocument is defined in Framework assembly rather than ArcMapUI assembly, is this a bug for this OMD?
Thanks for your input.
Wei
