what is the "Dissolve" tool for rasters?
3466
14
05-26-2011 10:29 AM
JamalNUMAN
Legendary Contributor
please, see the attached image that shows my question
I'm trying to dissolve the cell of the raster based on the Iprime field, but couldn't fine an equivalent tool.
I tried to use the "reclassify" tool but resulted raster was meaningless!
thank you
regards
Jamal
Jamal Numan
KylePurdon
It depends on what you want to do with the raster. You could just create a new raster where the field you want is the "Value" field and then just use that raster as a "zone". Or you could just change the symbology so that it represents the field you want.
Another method would be to covert your raster to a polygon based on the field you want, then use the dissolve and convert back to a raster. As far as I know there is no "raster dissolve" tool.
You could also use some sort of conditional statement as well if you want to dive into that.
JamalNUMAN
Thank you for the answer Kyle.
please, have a look on the attached image that shows that i cant convert the raster to polygons according the Iprime field that contain real numbers
what I'm looking for is to have a raster that has only the values: 0.2, 0.4, 0.6, 0.8 and 1. (out of the given raster)
then this raster (Iprime) is intended to be combined with another raster (CtachType) that has the values: a, b, c and d.
then a field is added to the combined raster and its values are calculated according to the following if statement:
if [CtachType] = "a" then
Select Case [Iprime]
Case .2
OP= 0
Case .4
OP= 0
Case .6
OP= 0
Case .8
OP= 0
Case 1
OP= 0
end select
else
if [CtachType] = "b" then
Case .2
OP= .2
Case .4
OP= .4
Case .6
OP= .6
Case .8
OP= .8
Case 1
OP= 1
end select
else
if [CtachType] = "c" then
Case .2
OP= .4
Case .4
OP= .6
Case .6
OP= .8
Case .8
OP= 1
Case 1
OP= 1
end select
else
if [CtachType] = "d" then
Case .2
OP= .6
Case .4
OP= .8
Case .6
OP= 1
Case .8
OP= 1
Case 1
OP= 1
end select
end if
end if
end if
end if
this is why i need the resulted raster to have only the values  0.2, 0.4, 0.6, 0.8 and 1.
but how can i do that?
regards
Jamal
Jamal Numan
KylePurdon
This is a long shot but maybe the Raster to Polygon tool wont work with decimals. Try multiplying the field by 10 and then converting Raster - Polygon. This would make 1 = 10 0.8 = 8 and so on.
DanPatterson_Retired
convert the tif to an ESRI grid using the IPRIM field
JamalNUMAN
but using which tool can i convert the TIF to ESRI GIRID?
Jamal Numan
PatrickTaurman
Occasional Contributor III
Use the Lookup tool.  It will take a raster, and use a field, and make a new raster.  To output a ESRI Grid, just don't put an extension on the end of the name (i.e. instead of test.tif just call it test).
If you are just looking to go from Tiff to Grid, just use Copy Raster.
JamalNUMAN
What i'm looking for is to have a dissolved raster of values: 0.2, 0.4, 0.6, 0.8 and 1.
please, see the attached images that show that the "lookup" too is not helpful to achieve what I'm looking for
what else i may try?
Jamal Numan
PatrickTaurman
Jamal, I would contact Support and open an incident with them.  It looks like you are having issues with that dataset in multiple tools.  Without the data in hand, it's going to be difficult to guess what the problem is.
JamalNUMAN
the data is attached
thank you
Jamal
Jamal Numan
