ScottChang25
ArcGIS 10:To Create File Geodatabase,Feature Dataset, and Feature Class-No map output
Discussion created by ScottChang25 on Apr 26, 2011
Latest reply on May 3, 2011 by ScottChang25
Hi all,
I use ArcGIS 10 to do the Applications: Vector Data Model  in the Chapter 3 of the book �??Introduction to Geographic Information Systems (5th Edition)�?� by K. T. Chang to gain the skills of adding the data of GIS Points, Lines, and Polygons into the ArcMap via the GeoDatabases of ArcCatalog.  I just completed the Task 2: Create File Geodatabase, Feature Dataset, and Feature Class. I found that there is no polygons of elevzone and no polylines of stream shown in the map for the Area_1 �?? please see the attached file.   I have no ideas why I did not get the polygons of elevzone and the polylines of streams of the Area_1 in the map!!!   Could you please kindly tell me why I did not get the polygons of elevzone and the polylines of streams of the Area_1 in the map and how I can correct these mistakes?   Please kindly respond.
Thanks in advance,
Scott Chang
Outcomes
