Hornbydd
Bug in ArcGIS 10 ~ draw errors when table is joined
Discussion created by Hornbydd Champion on Apr 14, 2011
Latest reply on Jun 13, 2012 by ckizer
All,
Can someone from ESRI or the community at large confirm if the following is a bug in ArcGIS 10?
I have a point featureclass in a personal geodatabase. I have a field called action that stores the codes N,D,M or G. I've set up a label class where D and G display an empty string and M and N display the text in a field called SURTAGID (see attached screen shot). In this non-joined state everything is working as expected.
I have a non geodatabase Access database with a table in it which I join to my point featureclass based upon the TagID fields (the highlighted field in my image). As soon as I make the join I get all the draw errors and everything fails to display.
I've also noted that if I click on the Expression button I see all my fields prefixed by the appropriate table name([fcPoint.SURTAGID]) but in the label field drop-down one only sees the field name...
Duncan
Outcomes
