Problem with geometry methods - Within/Contains
422
03-16-2011 07:56 PM
TrungTran
Hello everyone,
I am trying to check if a polygon is within a mask, which is another polygon. To do this, I use the method CONTAINS. However, this method seems to be wrong because it returns FALSE but in fact it should be TRUE.
I am attaching here the mask shapefile and below is the code.
def createPolygonCell(intCellsize, leftX, upperY):
    aPoint1 = arcpy.Point()
    aPoint2 = arcpy.Point()
    aPoint3 = arcpy.Point()
    aPoint4 = arcpy.Point()
    aPoint1.X = leftX
    aPoint1.Y = upperY
    aPoint2.X = leftX + intCellsize
    aPoint2.Y = upperY
    aPoint3.X = leftX + intCellsize
    aPoint3.Y = upperY - intCellsize
    aPoint4.X = leftX
    aPoint4.Y = upperY - intCellsize
    array= arcpy.Array()
    array.add(aPoint1)
    array.add(aPoint2)
    array.add(aPoint3)
    array.add(aPoint4)
    array.add(aPoint1)
    aPolygon = arcpy.Polygon(array)
    array.removeAll()
    return aPolygon
rows = arcpy.SearchCursor(inMaskShp)  #inMaskShp is the input mask shapefile attached
row = rows.next()
inMask = row.getValue("Shape")   #inMask is the first polygon of the inMaskShp
apoly = createPolygonCell(30, 565845, 3881985)
apoly.within(inMask)   #this returns FALSE although it should be TRUE
I do export inMask and apoly to shapefiles to double check whether apoly is within inMask.
Also, the method CONTAINS returns FALSE as well. And it is not correct.
In addition, interestingly, the four corners of the apoly (which is a little square) are within inMask when I use apoint.within(inMask).
Could anyone please shed a light on this (i.e. how to check a poly within another poly)?
Thanks.
DanPatterson_Retired
without examining the details of your situation in detail, you should be aware that problems have been discovered when using arcpy's geometry objects when no spatial reference is specified.  a protracted discussion is noted in:
http://forums.arcgis.com/threads/9763-Errors-in-arcpy-s-Polygon-class
there is a NIM number which you can track the error on
NIM059845
which indicates that it is resolved as of version 10 SP2 and in 10.1
http://resources.arcgis.com/content/nimbus-bug?bugID=TklNMDU5ODQ1
TrungTran
Thanks Dan.
Could you please let me know where I can download SP2? I just can't find it myself. Thanks.
NIM059845
which indicates that it is resolved as of version 10 SP2 and in 10.2
I don't think it is out yet...so use the workaround in the interim
TrungTran
OK. Thanks Dan.
