gregkirton1
Smoothing the lines on the polygons within a DEM
Discussion created by gregkirton1 on Feb 18, 2011
Latest reply on Feb 22, 2011 by gregkirton1
I'm trying to smooth the rough edges around the separations between the classes in a DEM that I'm working with. Smooth polygon under cart tools doesn't work because its not a polygon.. doesn't even give you the option to try. I switched the DEM from the stretched colour ramp to the classes option.
So I was wondering if there is a way I can directly smooth that out.. or I probably have to convert it first to something, somehow?
Any help or ideas to do this would be very much appreciated. I attached the image of what I've got after displaying the DEM as classes. Also, I'm using Arc10
Greg
Outcomes
