Doh! ArcGIS 10 - ArcInfo
Thanks Duncan, I read up on these "iterators". I kind of understand from the example what the Feature Selection iterator is doing. However, are the facilities the input or the buffer? The Facilities right? And Ill have to create the buffer as a second model and use that as the precondition to the Feature Selection?
Besides, I still don't understand how the FAC ID will be added to the summary table to enable a join back to the Facility features. I'm not sure it helps but I decided to make the Buffer Dissolve type = List and expose the Dissolve field parameter which I can pass on the FAC ID to the buffer layer input.
I assume, the output summary table will include the Feature Selection Group value for each row. Yes? If so, then using the FAC ID as the group from the buffer layer will be in the output summary table which will become a precondition to the join of the original facilities layer and the output. Yes?
And do I need to do anything with the Feature Selection Value?
I've attached my latest attempt.
Cheers,
m.
