This is the code for counting the number of nodes and edges for a topology.
Private Sub CursorCount_MouseDown(ByVal button As Long, ByVal shift As Long, ByVal x As Long, ByVal y As Long)
Dim pmXDoc As IMxDocument
Set pmXDoc = ThisDocument
Dim pTopologyLayer As ITopologyLayer
Dim pTopology As ITopology
Dim pTopoGraph As ITopologyGraph
Dim pCursor As ICursor
Dim pEnumTopoNode As IEnumTopologyNode
Dim i As Long
Dim pTopoNode As ITopologyNode
Dim penumNodeEdge As IEnumNodeEdge
Dim pTopoEdge As ITopologyEdge
Dim batfrom As Boolean
Dim pPolyline As IPolyline
Dim pEnv As IEnvelope
Dim pRubber As IRubberBand
Set pRubber = New RubberEnvelope
Dim pActiveView As IActiveView
Set pActiveView = pmXDoc.ActiveView
Set pEnv = pRubber.TrackNew(pActiveView.screenDisplay, Nothing)
Set pTopologyLayer = pmXDoc.FocusMap.Layer(0) 'A topology has to be in first position in the view Table of content
Set pTopology = pTopologyLayer.Topology 'Get the topology
Set pTopoGraph = pTopology.Cache 'Get the topologygraph
pTopoGraph.Build pEnv, False 'Build the topology graph
Set pEnumTopoNode = pTopoGraph.Nodes 'Get all the nodes of the graph
'For each nodes get the adjacent edges and print the length of the edges
MsgBox "Number of nodes : " & pEnumTopoNode.Count
For i = 0 To pEnumTopoNode.Count - 1
Set pTopoNode = pEnumTopoNode.Next
Set penumNodeEdge = pTopoNode.Edges(True) 'Get all the adjacent edges
MsgBox "Number of edges adjacent to that node : " & penumNodeEdge.Count
MsgBox "Is the enumerator Clockwise : " & penumNodeEdge.IsClockwise
penumNodeEdge.Next pTopoEdge, batfrom 'Get the next adjacent edge
While Not pTopoEdge Is Nothing
Set pPolyline = pTopoEdge.Geometry
Debug.Print "Length of polyline : " & pPolyline.Length
penumNodeEdge.Next pTopoEdge, batfrom 'Get the next edge
Wend
End Sub
But the counting result is wrong. Please see the picture in the attachment. The number of nodes in the area of the picture should be 1, but the result of the code is 4. Could you tell me how to fix it?
Saili
