aizat12345
Printing query/search result from map via javascript; How to????
Discussion created by aizat12345 on Dec 14, 2010
Latest reply on Dec 20, 2010 by lowgas
Hi I have designed a web mapping application that have some data search/query function. The result comes from the data that had been overlayed with the map and will be displayed on the map in the form of icons. I also had created a button to print the search result together with the map. The button will call another file which i named as print.html, where it will invoke the print function to print the map id together with the search/query result. My problem is that only the map is printed but not the search results.
This is my print.html
<h4> Printed Ver.</h4>
<script language="javascript">
var contents2 = window.opener.document.getElementById("map");
document.write(contents2.innerHTML);
window.print();
</script>
I would appreciate if anybody can help me with this issue.
I have attached also my web mapping script for reference
Outcomes
