jamesrichards
Bug: InfoWindow Draws Incorrectly When in Center of Screen
Discussion created by jamesrichards on Nov 18, 2010
Latest reply on Nov 22, 2010 by jamesrichards
Steps to reproduce:
1. In the Concepts section of the resources center, follow instructions in the topic: "Using the InfoWindow to create map tips", stopping just before the "Adding a details page" section.
2. In the MyMap_MapGesture handler, change GestureType.Hold to GestureType.Tap
3. Run the sample, tap on a state. The map centers and the InfoWindow draws as expected.
4. Tap away from a state to hide the InfoWindow.
5. Tap on the same state again. Now the InfoWindow appears but it draws as a rectangular block rather than drawing the Callout shape.
6. Pan the map and then tap on the same state again. Now when the map re-centers it draws correctly again.
So the issue is that if the graphic is already in the center of the screen, the InfoWindow doesn't draw correctly.
Outcomes
