jadams
SQLState NativeError
Discussion created by jadams on Nov 17, 2010
Latest reply on Jan 27, 2012 by kaspatoo
I'm trying to install SDE 64-bit on SQL Server Standard.  I'm able to login to the Management Studio using either Windows authentication or SQL Server authentication.  However, when I run the post install it will not create the repository.  It report SQLState and NativeError.  The log file report the same error but repeated over and over again with a different number each time.  See attached.
Specs:
Windows 2008 R2 64x
SQL Server Standard 64x
SDE 64x
Thanks.
Outcomes
