Playa
Arc Hydro - Batch Terrain Preprocessing - ArcCatalog
Discussion created by Playa on Oct 27, 2010
I'm currently using ArcGIS 9.3 SP1 and I have Arc Hydro 1.4 installed. I have attached a jpeg of my model where I have adjusted how the Threshold is calculated for Stream Definition. I would like to use this model when Batch Terrain Preprocessing is run. I can't figure out how to get my target locations set from ArcCatalog not ArcMap for all my subfolders which I would like to process. I need Arc Hydro to create the neccessary folder under each subfolder for the raster layers as well as the file geodatabase for the vector data. Any help will be appreciated.
Regards
Outcomes
