Adjust leading?
401
10-07-2010 11:48 AM
847396730
Occasional Contributor III
Hello!  Does anyone know how to adjust the leading in a stacked label?  I'd like to make the Alt symbol a shade smaller, but am restricted by how much space is required by the carriage return between 50 and A (see attached jpg).  Thoughts?  Thanks!
from ESRI:
Yes, you can reduce the leading on labels.  First, in the Layer Properties of the feature that is labeling, on the Labels tab, click the Symbol button �?? this will open the Symbol Selector dialog.  Next, click Edit Symbol which will open the Editor dialog.  On the Formatted Text tab, you can change the Leading which will change the space between the two lines.  Note the units at the top right and modify the value for the Leading using these units.  You will want to make this a negative value to reduce the spacing.
