Jamal432@gmail.com
Cadastral Editor: are we forced to re-enter the parcel number to the parcel inside th
Discussion created by Jamal432@gmail.com on Jul 2, 2010
Latest reply on Jul 2, 2010 by cleslie-esristaff
Cadastral Editor: are we forced to re-enter the parcel number to the parcel inside the cadastral fabric that contains the parcels?
Assuming that the data for parcels are available in polygon layer (name is ParcelLayer) which includes the most important field ( parcel number) then:
1. we convert this layer to polyline x_Arc
2. Then we use this layer x_Arc to build the other two layers (using build cadaster fabric source):
a. X_node
b. X_polygone
3. Then we build new fabric that builds inside it the layers below:
a. control
b. linepoints
c. points
d. lines
e. parcels
4. The problem now is to transfer the data from the original layer (parcel) to the layer parcels inside the fabric�?�! Where are the common field?
Therefore, three layers are created through this approach:
1. The original layer of parcels (polygons0
2. The x_polygon parcel
3. The parcels inside the cadastral fabric
In summary, are we forced to re-enter manually the parcel number?
Outcomes
