Web Safe Only Colors for Unique Value Renderer?
1235
05-27-2010 12:59 PM
AdamPfister
What color schemes (if any) are supported when using a unique value renderer in ArcMap?  If I choose to symbolize based on unique values, choose a field, add all fields, then choose the "Basic Random" color scheme, most if not all of the colors are reported as "Undefined" in the REST description.  I assume this is because the color is not web-safe?
How can we choose this option without having to go into each individual symbol and specify a safe color?
AdamPfister
Just got the word back from ESRI Tech Support that this is a bug @ v10 pre-release.
[#NIM057974  Publishing a MSD map service that has layers which is symbolized using unique values will return the color as "Undefined" in the REST Endpoint for the map service. ]
Using a MXD instead of an MSD will give you the correct color values and not an "Undefined" value.
