Riverside
Save Edits Crash
Discussion created by Riverside Champion on Jan 26, 2010
Latest reply on Jan 28, 2010 by Riverside
Trying to Stop Edits gave me an error, which I then closed the dialog, then I proceeded to Save Edits.  I received a crash at this time.  Will test more.  Basically I did a handful of things like set template properties, switched some reps around in the templates, set a date field in the template as well.  For edits, Cut one polygon, did some topology reshaping, did some topology modifies, used the edit vertices toolbar to manually move vertices, did some validate in specified extent, used the attributes window, used the topology editor window, lots of different things, see attachment for the error report.
I also had a display expression set.
Outcomes
