csingeu
org.brautaset.JSON framework error?
Discussion created by csingeu on Jul 25, 2010
Latest reply on Aug 22, 2012 by sunita@octaware.com
I have downloaded and installed the ArcGIS API for iOS (Update 1) and using iPhone SDK 4.0.
I was unable to build and run the "MyFirstMapApp" code.
Subsequently, I tried to run the default sample codes (MapView) included in the SDK, but it failed to run too. In both instances, the following error was display.
is there a problem with the org.brautaset.JSON framework?
Can anyone kindly advise?
Thanks.
2010-07-26 15:14:30.529 MapViewDemo[2511:207] -JSONValue failed. Error trace is: (
    "Error Domain=org.brautaset.JSON.ErrorDomain Code=3 \"Unrecognised leading character\" UserInfo=0x5c130e0 {NSLocalizedDescription=Unrecognised leading character}"
2010-07-26 15:14:31.411 MapViewDemo[2511:207] -JSONValue failed. Error trace is: (
    "Error Domain=org.brautaset.JSON.ErrorDomain Code=3 \"Unrecognised leading character\" UserInfo=0xd8013f0 {NSLocalizedDescription=Unrecognised leading character}"
2010-07-26 15:14:31.413 MapViewDemo[2511:207] *** Terminating app due to uncaught exception 'NSRangeException', reason: '*** -[NSMutableArray objectAtIndex:]: index 0 beyond bounds for empty array'
*** Call stack at first throw:
 0   CoreFoundation                      0x02643919 __exceptionPreprocess + 185
 1   libobjc.A.dylib                     0x027915de objc_exception_throw + 47
 2   CoreFoundation                      0x02639465 -[__NSArrayM objectAtIndex:] + 261
 3   MapViewDemo                         0x00046b71 -[AGSMapView layerDidLoadHandler:] + 313
 4   Foundation                          0x00116c1d _nsnote_callback + 145
 5   CoreFoundation                      0x0261bcf9 __CFXNotificationPost_old + 745
 6   CoreFoundation                      0x0259b11a _CFXNotificationPostNotification + 186
 7   Foundation                          0x0010c7c2 -[NSNotificationCenter postNotificationName:object:userInfo:] + 134
 8   Foundation                          0x00118b05 -[NSNotificationCenter postNotificationName:object:] + 56
 9   MapViewDemo                         0x000517a9 -[AGSTiledLayerView agsLayerDidLoad:] + 72
 10  CoreFoundation                      0x025b442d __invoking___ + 29
 11  CoreFoundation                      0x025b4301 -[NSInvocation invoke] + 145
 12  Foundation                          0x0012be9a __NSThreadPerformPerform + 251
 13  CoreFoundation                      0x02624d7f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
 14  CoreFoundation                      0x025832cb __CFRunLoopDoSources0 + 571
 15  CoreFoundation                      0x025827c6 __CFRunLoopRun + 470
 16  CoreFoundation                      0x02582280 CFRunLoopRunSpecific + 208
 17  CoreFoundation                      0x025821a1 CFRunLoopRunInMode + 97
 18  GraphicsServices                    0x02ea82c8 GSEventRunModal + 217
 19  GraphicsServices                    0x02ea838d GSEventRun + 115
 20  UIKit                               0x003bab58 UIApplicationMain + 1160
 21  MapViewDemo                         0x000024e4 main + 102
 22  MapViewDemo                         0x00002475 start + 53
 23  ???                                 0x00000001 0x0 + 1
terminate called after throwing an instance of 'NSException'
Outcomes
