Override Scale Range
836
06-30-2014 10:55 PM
SimonJackson
Occasional Contributor III
  • I applied a scale range to a layer within ArcGIS for Desktop.
  • I published this to a hosted feature service in ArcGIS Online (using my account which is Admin).
  • I added this layer to a webMap and saved.
  • Decide that I no longer need this scale range in place.
  • Web-map --> Layer --> Set Visibility Range --> Clear Scale levels
  • Save Web Map AND Save Layer, as per the docco
  • Log out and log back in (all of this has been done with my Admin account) - WebMap still has scale level set.
How do I override the original scale range?
I would prefer to not have to overwrite the existing service as its possible the original data has been lost/changed schema.
The REST endpoint for the hosted feature service still has Min. Scale: 144447.638571969.
Is it possible to change this either at the service level, the layer level, or at the web-map level?   The latter two I believe my steps above proove that its not working as expected?
MikeMinami
Esri Notable Contributor
ArcGIS Online can narrow the scale range of a given service, but it can't expand the scale range beyond what the service supports.
thanks,
Mike
SimonJackson
Thanks for prompt response Mike.
That makes sense, I was just wondering as the feature service was hosted on ArcGIS Online, there might have been a way at overriding it.
Will look at recovering data and overwriting service without the scale levels applied within the ArcGIS for Desktop environment.
Thanks.
