Enable Enterprise Geodatabase to new user's schem doesn't work
5614
15
06-30-2014 09:52 AM
MarioRocha
Hi!
I've tried to Enable Geodatabase to existing user, but the ArcGIS show me: "Executing: EnableEnterpriseGeodatabase "Database Connections\RNCET - GIS2.sde" "C:\Program Files (x86)\ESRI\License10.2\sysgen\keycodes"
Start Time: Mon Jun 30 14:48:38 2014
WARNING 000152: Geodatabase instance already exists.
Succeeded at Mon Jun 30 14:48:38 2014 (Elapsed Time: 0.14 seconds)"
I have already two users SDE(SYSTEM TABLES) and GIS(FEATURES), but I want to use a MULTIGEODATABASE  with the same oracle instance.
Configuration:
ArcGIS 10.2 64 bits, Windows 7 64 bits, Oracle 11g R2.
AsrujitSengupta
Regular Contributor III
Have a look at the below links:
Creating a geodatabase in a user's schema in Oracle:
http://resources.arcgis.com/en/help/main/10.2/index.html#//002n0000000s000000
Connections to user-schema geodatabases in Oracle:
http://resources.arcgis.com/en/help/main/10.2/index.html#//002n00000031000000
VinceAngelo
Esri Esteemed Contributor
You'd need to give us all the parameters you're providing (less passwords, of course) in order
for us to tell why you're getting this response.
I do have to object to wanting to implement user-schema geodatabases with only one user.
There are a number of quirks to the way that user-schema geodatabases operate, and not
many business rules that call for them, even with scores of users and tens of thousands of
tables, so I do wonder if you might be borrowing trouble in this case.
- V
MarioRocha
Sorry guys!
So let's go!
I need to create a scenario using "Production and Publication Geodatabases", but only one instance Oracle 11g R2, in the same tablespace.
Following steps below:
1) In Oracle, I created the SDE user with privileges for CRATING an SDE master geodatabase. In ArcGIS > ArcCatalog > Data Management > Enable Enterprise Geodatabase > SDE Connection;(OK)
2) In Oracle, I created the GIS user with privileges for UPGRADING an SDE master geodatabase. (OK)
3) In Oracle, I created the SDE2 user with privileges for CRATING an SDE master geodatabase. In ArcGIS > ArcCatalog > Data Management > Enable Enterprise Geodatabase > SDE Connection;(ERROR)
Why the third step doesn't work?
MarioRocha
VinceAngelo
As noted in the referenced thread, you cannot create two independent "master"
geodatabases in the same Oracle 11g instance.  You could just use two different
users in a single instance, or you could use the same owner name in two Oracle
instances.  It would be unwise to use the same tablespace(s) in the former
configuration.
- V
MarioRocha
configuration.
- V
"You could just use two different users in a single instance" So I have tried it, but no sucess!!!
When I try on the second user connection to "Enable Enterprise Geodatabase", it doesn't work!
I using sdo_geometry type, isn't it problem???
VinceAngelo
No, I mean two different users with tables in ONE geodatabase.  Unless you've
got hundreds or thousands of tables in each user, and need to be able to upgrade
one instance before the other, then you're trying to apply a very sophisticated
solution to a mundane problem.  User-schema instances won't give you that
level of independence anyway, so it's far better to fall back to the "two instances"
solution if you need independence.
- V
MarioRocha
I'm not DBA, so I don't have all privilegies.
I created SDE and GIS users in Oracle, after I Enable Enterprise Geodatabase to SDE Connection created.
I understood that I can only one master geodatabase, but why doesn't work GDB tables in another user in the same instance?
MarioRocha
Thank's!
But I don't have another way, I have only one instance and I don't have DBA(SYS) privilegies, so I have to solve it anyway!
