Show Feature Service in Catalog
507
06-25-2014 03:05 AM
HaniDraidi
Occasional Contributor II
How to show feature Service in catalog, I published a service using ArcGIS Server, and enabled the feature access capability, so there are two services: map service and feature service. In the catalog window, I see only the map service! Whereas in the services directory there are two services. I need it to be available in the catalog, so I can right click it and create a layer, which is an input for another tool(Add feature Service URL to AXF) that requires a layer from feature server. The question is: How to show feature Service in catalog if possible, or how to create a layer from feature service layer?
RussellBrennan
Hani,
If you connect using an 'admin' connection in ArcMap/ArcCatalog you will only see the map service. If you connect using a 'user' connection you will see both the feature service and map service.
Take a look at the 3 links at the top of this page for more info: http://resources.arcgis.com/en/help/main/10.1/index.html#//006600000450000000
HaniDraidi
Russell,
Thank you very much, I tried it and it worked fine .
