Is it possible to assign a coded value domain to a field already populated with data? Does it depend on whether the existing data matches values in the domain? If it's not possible to do this, is there a workaround, e.g. creating a new field, assign the domain, move data over and delete old field?
After assigning the coded value domain - if there are values that do not match then the actual value will be shown in the attribute table instead of the coded value.
