c4i
3 Anchor Polyline Symbols are Drawn Incorrectly
Discussion created by c4i on Jun 23, 2014
Latest reply on Jun 24, 2014 by c4i
Runtime version 10.2.3
Operating Sytem: Windows 7 Ultimate
Steps to reproduce:
1. Download, build, and run the ArcGIS Runtime SDK sample from arcgis-runtime-samples-dotnet
2. Navigate to Symbology -> Advanced -> Symbol Dictionary Search.
3. In the geometry type drop down menu, select "Line"
4. in the Symbol Results list, select Obstacle Effect Disrupt F (GFMPOED---****X)
5. Draw 3 points
Expected Result:
The symbol is drawn with points 1 and 2 defining the end points of the graphic's vertical line, and point 3 defining the tip of the longest arrow. Please see the MIL-STD-2525C official documentation (http://www.mapsymbs.com/ms2525c.pdf page 581).
Actual Result:
- the graphic's vertical line is a set length (i.e. the distance between point 1 and point 2 do not determine the length of the graphic's vertical line).
Additional Testing:
- All 3 anchor polyline symbols seem to have this issue (another symbol that does not work is Ambush F (GFGPSLA---****X))
Outcomes
