BA Data
2661
5
06-23-2014 06:46 AM
MikeRudibaugh
Group,
I have a question relating to the data for the Businesses from the third party InfoGroup.
The sales volume data used to be in 1000's.  You would take the number and add three 0's.
With my new install 2013 on 10.2, from my analysis, this makes no sense with some local employers. When I add three 0's to some of my small rural employers in east-central, IL we have employers doing over 1 billion in sales for 2013. This is simply not possible in our local economy. Could someone verify how we should use or evaluate the sales volume data for the 2013 data on business sales volume with the 2013 data?
Jason_RobinsonRobinson
Group,
Mike,
Yes the Dun & Bradstreet business data in the Esri 2013/2018 data release changed things.  Where previously SALES_VOL one did add the three zeros.  Below is copied directly from the 2013_USA_DandB_Business_Listings_Data_Descriptions.pdf located in the C:\ArcGIS\Business Analyst\US_2013\Documentation for clients that have Business Analyst Desktop.
Sales Volume/Assets (SALES_VOL) ??? Estimated sales or assets in U.S. dollars.
This is a change from prior years where sales volume was reported in thousands of dollars.
Regards,
Jason R.
Group,
Mike,
Regards,
Jason R.
MikeRudibaugh
Thanks, Jason!
MikeRudibaugh
Jason,
I do have a follow-up for you. Did the Dun & Bradstreet business 2013-2018 data replace the old data source from
the Info Group.  I assume that Esri built a new third party partner to populate the business data in the Business Analyst Extension.
Mike
Jason,
Mike
Mike,
Yes just a data vendor switch for the business data.
2012= InfoGroup
2013= Dun & Bradstreet
Naturally support received a lot of call when clients where compare 2012 reports that leverage business data with 2013 because of very different methodologies not only to collection but also sales volume/total employees calculations.
Regards,
Jason R.
ahourazandiatashbar
I have further question about SALESVOL variable. It is indicated that the SALESVOL is not the actual sales volume but is modeled. How can get to learn more about this model?
