Cannot update layer symbology
3046
06-20-2014 02:17 PM
curtvprice
MVP Esteemed Contributor
I am trying to follow the example in the help for Layer:
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Census")[0]
lyr = arcpy.mapping.ListLayers(mxd, "StatePopulation", df)[0]
lyrFile = arcpy.mapping.Layer(r"C:\Project\LYRs\Population.lyr")
arcpy.mapping.UpdateLayer(df, lyr, lyrFile, True)
if lyr.symbologyType == "GRADUATED_COLORS":
  lyr.symbology.valueField = "POP2000"
  lyr.symbology.numClasses = 4
  lyr.symbology.classBreakValues = [250000, 999999, 4999999, 9999999, 35000000]
  lyr.symbology.classBreakLabels = ["250,000 to 999,999", "1,000,000 to 4,999,999",
                                    "5,000,000 to 9,999,999", "10,000,000 to 35,000,000"]
Here is my pathetic dialog with the Python window...
>>> mxd = am.MapDocument("current")
>>> df = am.ListDataFrames(mxd, "ValueMap")[0]
>>> df.name
u'ValueMap'
>>> lyr = am.ListLayers(mxd, "County*", df)[0]
>>> lyr.name
u'County Data'
>>> am.UpdateLayer(df, lyr, am.Layer("q.lyr"), True)
u'AQ_WGWTo.AQ_WGWTo_2010'
>>> lyr.symbologyType
u'GRADUATED_COLORS'
>>> lyr.symbology.numClasses = 5
Runtime error
  File "<string>", line 1, in <module>
  File "c:\arcgis\desktop10.2\arcpy\arcpy\arcobjects\_base.py", line 89, in _set
    return setattr(self._arc_object, attr_name, cval(val))
RuntimeError
>>> # however this works - and displays immediately in the map (with unchanged symbology)
>>> lyr.symbology.valueField = u'AQ_WGWTo.AQ_WGWTo_2000'
>>> # and this generates no error but does not change the break values as promised
>>> lyr.symbology.reclassify()
Any ideas what I'm doing wrong????
curtvprice
Sorry to bother everyone. When I copy the data to the table and remove the active join from the layer, everything works as advertised. So, don't use the reclassify method does not work for me if there a join on the layer.
I reproduced this problem with 10.1 SP 1 and 10.2.2. Argh.
