geometry storage
710
5
06-19-2014 03:56 AM
SyedMasood_Khadri
New Contributor III
hi
I want to change dbtune parameter for geometry_storage from st_geometry to sdo_geometry.
ArcSDE installed on windows 2008 R2, oracle client is 64-bit.
I have used  sdedbtune command but not succesful to change geometry_storage
Please help me..
JakeSkinner
Esri Esteemed Contributor
Hi Syed,
Your command looks correct, you will just need to specify the '-i' parameter, which will be the           ArcSDE service name, port number, or direct connection information.  Ex:
-i sde:oracle11g:ORCL
ORCL above is the Oracle instance.
VinceAngelo
Please provide:
  • A complete description of the software environment (exact database
  • release, exact client version, and exact ArcGIS release)
  • The exact contents of the DBTUNE file you attempted to upload
  • The exact command you used to upload the DBTUNE changes
  • (less password, of course)
  • The exact keyword you used on subsequent feature class creation
  • The exact output of 'sdelayer -o describe_long' on the created layer
- V
SyedMasood_Khadri
New Contributor III
hi
(1) Oracle server 11.2.0.1.0 on Redhat linux 5.
(2) Oracle client (64 bit), ArcSDE 10.1 installed on Windows 2008 R2.
(3) ArcGIS desktop 10.1, Oracle client (32 bit) on Windows 7 (direct connection is succesful with oracle serever).
The following command is used where ArcSDE is installed.
sdedbtune -o alter -k defaults -P geometry_storage -v sdo_geometry -s 194.61.63.132 -D newdb -u sde
ArcSDE 10.1
Attribute        Administration Utility
Error: Entry for SDE instance not found in services file (-102).
Error: Could not create a connection on server 194.61.63.132, for user sde.
JakeSkinner
Hi Syed,
SyedMasood_Khadri
New Contributor III
hi, really thanks for that.
VinceAngelo
It has been a long time since Service Pack 1 to ArcGIS 10.1  was
released, and the Quality Improvement Patch is getting long
in the tooth as well. Both should be applied to all ArcGIS 10.1
installations.
- V
