joe.wang
Double click on layer doesn't enlarge the map in the IE10
Discussion created by joe.wang on Jun 9, 2014
Latest reply on Jun 12, 2014 by joe.wang
Hi Everyone, I just joined here and this is my first question here, If I did something wrong ,Please kindly correct me . thanks.
I am just a newbie of Arcgis javascript , I created a map which contains a layer . The layer has pop-up infowindow whenever I click on the layer.
The webmap can be viewed from https://accela.maps.arcgis.com/home/webmap/viewer.html?webmap=8e900bdba72f451cbf5141a9a6073532
and Currently the map can be shown successfully in my web site except a problem .
I used below code to generate the map.
var mapDef = esriUtils.createMap("8e900bdba72f451cbf5141a9a6073532", "divMap");//divMap is an id of div.
mapDef.then(lang.hitch(this, function (response) {
                var map = response.map;});
I found If I viewed it in the browser chrome/Firefox/IE9. Double-click on the layer will zoom-in the map immediately.  But if I view it within IE10/IE11 . double-click will pop up a infowindow which contains a link "zoom to"  to make the map zoom in.
So my question is can I disable the popup infowindows and just enlarge the map immediately when double click on my layer in IE10 ? (I just want only the single click to popup property window.)
If it can not be made or Arcgis doesn't support, Someone please tell me , thanks you in advance.
Any comments are appreciated.
Joe
Outcomes
