AnsweredAssumed Answered
Can't zoom to feature from Datagrid
Question asked by rcsellman on Jun 9, 2014
Latest reply on Jun 12, 2014 by kenbuja
I have a find task in my application that returns features that are points, lines and polygons.  I can get the search to populate the datagrid but I am having problems with my onRowClickHandler function and zooming to those features from the datagrid.  I've been searching through the forums and see that zooming to a point from the datagrid has been an issue for others, but I can't find a solution that works for me.  Here is some code that shows the findtask and what I have for the onRowClickHandler function.
I get the error: "Uncaught TypeError: Cannot read property 'getExtent' of undefined" when the onRowClickHandler function is fired.
findDistrictTask = new FindTask("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES/MapServer/");          map.on("load", function () {             findDistrictParams = new FindParameters();             findDistrictParams.returnGeometry = true;             findDistrictParams.layerIds = [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12];             findDistrictParams.searchFields = ["NAME, UNAME, PUMPID, PIPEID, PlantID, Name"];             findDistrictParams.outSpatialReference = map.spatialReference;         });          function doDoesDistrictFind() {             findDistrictParams.searchText = dom.byId("doesDistrictText").value;             findDistrictTask.execute(findDistrictParams, showResults);         }           function showResults(results) {             var markerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_SQUARE, 10, new SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));             var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);             var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));             map.graphics.clear();             var dataForGrid = [];             arrayUtils.map(results, function (result) {                 var graphic = result.feature;                 dataForGrid.push([result.layerName, result.foundFieldName, result.value]);                 switch (graphic.geometry.type) {                 case "point":                     graphic.setSymbol(markerSymbol);                     break;                 case "polyline":                     graphic.setSymbol(lineSymbol);                     break;                 case "polygon":                     graphic.setSymbol(polygonSymbol);                     break;                 }                 map.graphics.add(graphic);             });             var data = {                 items: dataForGrid             };             var store = new ItemFileReadStore({                 data: data             });              var grid = registry.byId("grid");              grid.setStore(store);             grid.on("rowclick", onRowClickHandler);              map.centerAndZoom(center, zoom);         }          function onRowClickHandler(evt) {             var clickedFeature = evt.grid.getItem(evt.rowIndex).OBJECTID;             var selectedFeature = arrayUtils.filter(map.graphics.graphics, function (graphic) {        return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedFeature);       });        var featureExtent = selectedFeature.geometry.getExtent();    var screenpoint = map.toScreen(selectedFeature.geometry.getExtent().getCenter());    var mappoint = map.toMap(screenpoint);        map.centerAt(mappoint);                 if (selectedFeature.geometry.declaredClass == 'esri.geometry.Point') {                 map.centerAt(selectedFeature.geometry);             } else {                 var featureExtent = selectedFeature.geometry.getExtent();                 var screenpoint = map.toScreen(selectedFeature.geometry.getExtent().getCenter());                 var mappoint = map.toMap(screenpoint);                 map.centerAt(mappoint);             }       }
Does anyone have any idea what I am doing wrong or a way to zoom to all feature types from a datagrid?  Thanks in advance!!!
Outcomes
