Hi,We just upgrade from ArcObjects 10.1 to 10.2.2 and now we're having a problem where the Geographic Coordinate System (GCS) object gets corrupted after calling the DefineEx (or Define) method a few times (see code sample 1). I found a workaround by pulling the GCS object from a projection coordinate system object (see code sample 2).Is there any reason for this behavior and how can I create a Geographic Coordinate System from a factory code? Thanks,NiroCode Sample 1
int numberOfErrors = 0;
for (int i = 0; i < 1000; i++)
var spatialReferenceFactory = new SpatialReferenceEnvironmentClass(); //(ISpatialReferenceFactory4)Activator.CreateInstance(Type.GetTypeFromProgID("esriGeometry.SpatialReferenceEnvironment"));
var geographicCoordinateSystem = spatialReferenceFactory.CreateGeographicCoordinateSystem((int)esriSRGeoCSType.esriSRGeoCS_NAD1983) as IGeographicCoordinateSystem;
// var projectedCoordinateSystem = spatialReferenceFactory.CreateProjectedCoordinateSystem((int)esriSRProjCSType.esriSRProjCS_NAD1983UTM_17N);
// var geographicCoordinateSystem = projectedCoordinateSystem.GeographicCoordinateSystem;
(geographicCoordinateSystem as IGeographicCoordinateSystemEdit).DefineEx(
geographicCoordinateSystem.Name,
geographicCoordinateSystem.Alias,
geographicCoordinateSystem.Abbreviation,
geographicCoordinateSystem.Remarks,
geographicCoordinateSystem.Usage,
geographicCoordinateSystem.Datum,
geographicCoordinateSystem.PrimeMeridian,
geographicCoordinateSystem.CoordinateUnit);
if (String.IsNullOrEmpty(geographicCoordinateSystem.Name))
numberOfErrors++;
Code Sample 2
// var geographicCoordinateSystem = spatialReferenceFactory.CreateGeographicCoordinateSystem((int)esriSRGeoCSType.esriSRGeoCS_NAD1983) as IGeographicCoordinateSystem;
numberOfErrors++;
