AnsweredAssumed Answered
TOC Example
Question asked by jay.kapalczynski on Jun 4, 2014
Latest reply on Oct 3, 2014 by kenbuja
Trying to get the TOC example working
http://www.arcgis.com/home/item.html?id=9b6280a6bfb0430f8d1ebc969276b109
I downloaded the files ... USING 2.10 ...I get most of the website to display including the map but nothing in the TOC shows up.
I am using the code pretty much using the code from the Source HTML.
I put a few Alerts in the code below...I am getting Alert 1,2,4 BUT for some reason not Alert 3
anyone have any thoughts as to why the TOC is not appearing and why I am not getting into Alert 3
 <!DOCTYPE html> <html>     <head>         <meta http-equiv="Content-Type" content="text/html; charset=utf-8">         <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />         <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>         <title>TOC</title>         <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css">         <link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.9/js/esri/css/esri.css" />         <link rel="stylesheet" type="text/css" href="src/agsjs/css/agsjs.css" />         <style>             html, body {                 height: 98%;                 width: 98%;                 margin: 0;                 padding: 5px;                 font-family: helvetica, arial, sans-serif;                 font-size: 90%;             }              #leftPane {                 width: 280px;                 overflow: auto             }              /* this line hide layers when out of scale for the inline TOC */             .agsjsTOCOutOfScale {                 /*  display: none;*/             }         </style>         <script type="text/javascript">                      // helpful for understanding dojoConfig.packages vs. dojoConfig.paths:                   // http://www.sitepen.com/blog/2013/06/20/dojo-faq-what-is-the-difference-packages-vs-paths-vs-aliases/                   var dojoConfig = {                     paths: {                       //if you want to host on your own server, download and put in folders then use path like:                             agsjs: location.pathname.replace(/\/[^/]+$/, '') + '/src/agsjs'                         }                   };         </script>          <script src="https://js.arcgis.com/3.8/">         </script>          <script type="text/javascript">             var map, toc, dynaLayer1, dynaLayer2, featLayer1;              require(["dojo/_base/connect",     "dojo/dom", "dojo/parser","dojo/on", "dojo/_base/Color",     "esri/map",     "esri/geometry/Extent",     "esri/layers/FeatureLayer",     "esri/layers/ArcGISTiledMapServiceLayer",     "esri/layers/ArcGISDynamicMapServiceLayer",     "esri/symbols/SimpleFillSymbol",     "esri/renderers/ClassBreaksRenderer",     "agsjs/dijit/TOC",     "dijit/layout/BorderContainer",     "dijit/layout/ContentPane",     "dojo/fx", "dojo/domReady!"], function(connect,  dom, parser, on,Color,     Map, Extent, FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,     SimpleFillSymbol,ClassBreaksRenderer,     TOC){                // call the parser to create the dijit layout dijits               parser.parse(); // note djConfig.parseOnLoad = false;                map = new Map("map", {                 basemap: "topo",                 center: [-85.75, 38.25],                 zoom: 13               });    dynaLayer1 = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyOperationalLayers/MapServer", {         opacity: 0.8               });               featLayer1 = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1", {                 mode: FeatureLayer.MODE_SNAPSHOT,                 outFields: ["POP07_SQMI"]               });               featLayer1.setDefinitionExpression("STCOFIPS='21111'"); //Louisville, KY  alert("1");        map.on('layers-add-result', function(evt){                 // overwrite the default visibility of service.                 // TOC will honor the overwritten value.                  dynaLayer1.setVisibleLayers([2, 5, 8, 11]);                 //try {                    toc = new TOC({                     map: map,                     layerInfos: [{                       layer: featLayer1,                       title: "FeatureLayer1"                     }, {                       layer: dynaLayer1,                       title: "DynamicMapServiceLayer1"                       //collapsed: false, // whether this root layer should be collapsed initially, default false.                       //slider: false // whether to display a transparency slider.                     }]                   }, 'tocDiv');                   toc.startup();  alert("2");                    toc.on('load', function(){ alert("3");            if (console)                       console.log('TOC loaded');                     dom.byId("ChangeFeatureRenderer").disabled = false;                     dom.byId("SetVisibleLayersProgramatically").disabled = false;                     dom.byId("FindNodeByLayer").disabled = false;                     dom.byId("InsertNewLayer").disabled = false;      dom.byId("HandleNodeCheckEvent").disabled = false;                    });                  //} catch (e) {  alert(e); }               });                map.addLayers([dynaLayer1, featLayer1]);  alert("4");    // REMOVED ACTIONS HERE ARE IN THE NEXT POST               });         </script>     </head>     <body class="claro">         <div id="content" data-dojo-type="dijit/layout/BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">             <div id="header" data-dojo-type="dijit/layout/ContentPane" region="top">                 <div>                     <b>Table Of Content (TOC/Legend) Widget</b>                     <a href='toc_classic.html'>Classic Style </a>                     | <a href='toc.html'>AMD style</a>                     <div style="right:20px;position: absolute">                         <a href="../docs/toc/examples.html">Documentation</a>                     </div>                 </div>                 <ul style="margin:2px">                     <li>                         Click check box in TOC to turn on/off layers. When click on groups, all sublayers will be turned on/off.                     </li>                     <li>                         Click                         <button id="ChangeFeatureRenderer" disabled="disabled">                             ChangeFeatureRenderer                         </button>, notice in "FeatureLayer1", TOC refreshed to reflect the new renderer of FeatureLayer.                     </li>                     <li>                         Click                         <button id="SetVisibleLayersProgramatically" disabled="disabled"">                             SetVisibleLayersProgramatically                         </button>                         to programatically turn layer on/off (Set DynaLayer1 [8, 17, 18, 19, 20] on), notice TOC automatically sync with model(no refresh needed).                     </li>                     <li>                         Click                         <button id="FindNodeByLayer" disabled="disabled">                             FindNodeByLayer                         </button>                         to programatically find node for layer inside a map service, then either hide (layer id=12,"Damage Assessment") or collapse (layer id=0,"Public Safety") it.                     </li>                     <li>                         Click                         <button id="InsertNewLayer" disabled="disabled">                             InsertNewLayer                         </button>                         to programmtically insert a layer (DynamicMapServiceLayer2, Census) then refresh TOC.                     </li>      <li>                         Click                         <button id="SetOpacity" disabled="disabled">                             SetOpacityProgramitically                         </button>                         to programmtically set transparency of a newly added layer to 0.2 with slider enabled (after click "InsertNewLayer").                     </li>      <li>                         Click                         <button id="HandleNodeCheckEvent" disabled="disabled">                             HandleNodeCheckEvent                         </button>                         Handle Check Event to allow only one layer visible in "public saftety" service. When a layer is checked on, all other layers are off.                     </li>                 </ul>             </div>             <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true">                 <div id="tocDiv">                 </div>             </div>             <div id="map" data-dojo-type="dijit/layout/ContentPane" region="center">             </div>         </div>     </body> </html>
Outcomes
