Just gotta ask, is ESRI going to support the new Swift language for iOS?
1541
6
06-03-2014 02:52 PM
JerryChapman
ESRI going to support Swift programming language?
Jerry
Nicholas-Furness
So far, it seems to be working...  The key was to add ArcGIS.h to the "Objective-C Bridging Header" setting under Swift Compiler - Code Generation of Build Settings.
Throwing this out there too... In the case where you have a Swift-only project, you can also do the trick described in this Gist.
You'll need an
import ArcGIS
statement in the .swift file too.
E.g.
import UIKit import ArcGIS  var tileUrl = "http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"  class ViewController: UIViewController {      @IBOutlet var mapView : AGSMapView          override func viewDidLoad() {         super.viewDidLoad()         // Do any additional setup after loading the view, typically from a nib.                  var myLayer = AGSTiledMapServiceLayer(URL: NSURL(string: tileUrl))         mapView.addMapLayer(myLayer)     } }
Enjoy!
Nick.
P.S. I guess I should add that (as mentioned in the Gist) this isn't supported by Esri yet. Use at your own risk 🙂
raffia
Very interesting, was wondering about the same thing. Also wondering for a first release, will all the funcctionalities of the sdk be preserved.
JohnDye
Occasional Contributor III
With ESRI going all in on Python, and Apple comparing Swift to Python several times at WWDC, I imagine ESRI will probably come to support it. I wouldn't expect to see it at the 2015 DevSummit, but hopefully 2016. The good thing is that since it is interoperable with Obj-C APIs, you should be able to mix-and match as needed until ESRI can release a full blown Swift SDK.
mikedavis2
The way I understand Apple's intentions I don't think there is anything for ESRI to support.  Xcode will create swift bindings to the Objective C classes automatically.
I guess they could start doing documentation and demos with swift code
rbae
New Contributor III
Nicholas-Furness
You'll need an
import ArcGIS
E.g.
Enjoy!
Nick.
DiveshGoyal
Thanks, Nick.
That gist works great!
