brassier
Versioning with trigger issue
Discussion created by brassier on Jun 3, 2014
Latest reply on Jun 3, 2014 by vangelo-esristaff
We are trying to apply a unique id to an attribute/field when the user adds and saves a point to a feature layer.  The unique id is the combination of an attribute value and an integer, Example: STEA123456.  123456 is unknown until the user saves the point because it must be unique.
We added an �??AFTER INSERT�?� trigger to the �??Add�?� table.  When a user adds a single point to the feature layer and clicks save, the unique id is generated successfully.  The problem occurs when the user adds multiple points and clicks save.  I�??ve seen two scenarios occur:
1. The address points are added but all have the same unique id.
2. The address points are not added.
Has anyone done a similar activity with versioning?  We're wondering if there are any Esri-specific limitations that may cause what we're seeing.
Environment:
Silverlight API for ArcGIS 3.1
ArcGIS Server 10.2
SQL Server 2008 R2 Standard Edition
Outcomes
