I am new user to ArcGIS 10.2. I am currently working on setting up a map for my asset inspectors for doing their surveys in the field. I want them to be able to edit the attributes but not edit the topology. Is there a way to lock the topology before I publish to Arc Collector?
If so, you can change the service, this is outlined here in the Enable edits section.
"Update feature attributes only is useful when you want editors to enter attribute information without changing any feature geometry. For example, you might have a set of observation towers whose locations should not be allowed to change, but whose attributes may be updated regularly."
Best,
Melanie S.
