When editing address points in ArcMap, often their significant lag (over one minuet) before the new point is seen on the dataframe
and its attributes represented in an attribute table. A work around for this problem is to remove the address point featureclass and re add it to ArcMap. This will temporally fix the problem. However, this process usually takes place at least twice a day and I must spend time re-symbolizing features. I am editing in an ArcSDE enterprise environment. Has anyone found any permanent fixes for this type
of problem? Would this type of problem have to do with the ArcMap application or the server that my data is hosted on?
