AnsweredAssumed Answered
onChange listener not firing
Question asked by alex92190 on Jun 2, 2014
Latest reply on Jun 2, 2014 by alex92190
Hi all,
I am trying to have one-button push to activate three different functions independently. Thre three functions are:
1st function: Extratct data per graphics
2nd function: extract data per query (county)
3rd function: extract data per query (unit)
The idea is that I would use a switch... case  statements and have a global variable that allows users to overwrite the value as such.
  on(dom.byId("sel_county"), "onChange", function () {             extractMethod = "extractByCounty";             console.log("You are selecting a county!");          });          on(dom.byId("sel_unit"), "onChange", function () {             extractMethod = "extractByUnit";             console.log("You are selecting a unit!");          });            function initSelectionToolbar() {             map.graphics.clear();              selectionToolbar = new Draw(map);             selectionToolbar.on("draw-end", function (e) {                selectionToolbar.deactivate();                 var symbol3 = new SimpleFillSymbol(                   "solid",                   new SimpleLineSymbol("dash", new Color([255, 0, 0]), 2),                   new Color([255, 255, 0, 0.25])                );                 var graphic = new Graphic(e.geometry, symbol3);                map.graphics.add(graphic);       extractMethod = "extractByPoly";             });          }           function activateTool(tool) {             map.graphics.clear();             // The draw.activate expects a string like "polygon" or "freehand_polygon".             selectionToolbar.activate(tool);          }               function myFunction() {     //var extractMethod = "extractByPoly";     //var extractMethod = "extractByCounty";     //var extractMethod = "extractByUnit";  switch (extractMethod) {         default:              //function extractData() {             //get clip layers             var clipLayers = [];             if (registry.byId("layer1").get("checked")) {                 clipLayers.push("SRA");             }             if (registry.byId("layer2").get("checked")) {                 clipLayers.push("Burn");             }             if (clipLayers.length === 0 || map.graphics.graphics.length === 0) {                 alert("Select layers to extract and draw an area of interest.");                 return;             }              var featureSet = new FeatureSet();             var features = [];             features.push(map.graphics.graphics[0]);             featureSet.features = features;              var params3 = {                 "Layers_to_Clip": clipLayers,                 "Area_of_Interest": featureSet,                 "Feature_Format": registry.byId("formatBox").get("value")             };              domStyle.set(loading2, "display", "inline-block");             gp.submitJob(params3, completeCallback, statusCallback2, function (error) {                 alert(error);                 domStyle.set(loading2, "display", "none");             });             //}             break;   case "extractByCounty":             //function executeQueryTask(county) {             var clipLayers = [];             if (registry.byId("layer1").get("checked")) {                 clipLayers.push("SRA");             }             if (registry.byId("layer2").get("checked")) {                 clipLayers.push("Burn");             }             if (clipLayers.length === 0) {                 alert("No layers to clip, please select a layer you would like to clip...");                 return;             }            var county = document.getElementById("sel_county").value             var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Counties/MapServer/0");             var query = new Query();             query.returnGeometry = true;             query.outFields = ["NAME_PCASE"];             query.where = "NAME_PCASE = '" + extractMethod + "'";             query.outSpatialReference = map.spatialReference;             queryTask.execute(query, function (featureSet) {        if (featureSet.features.length === 0) {                      alert("Query task did not return any features");                  return;                 } else {                 var AOI = featureSet.features[0].geometry;                 var graphic = new Graphic(AOI, symbol);                 var features = [];                 features.push(graphic);                 var fSet = new FeatureSet();                 fSet.features = features;                   var params = {                     "Layers_to_Clip": clipLayers,                     "Area_of_Interest": fSet,                     "Feature_Format": registry.byId("formatBox").get("value")                 };                    domStyle.set(loading, "display", "inline-block");                 gp.submitJob(params, completeCallback, statusCallback, function (error) {                     alert(error);                     domStyle.set(loading, "display", "none");                 });     }             });                     //}             break;
The default in the switch statement works normally. However, the two other statemnets dont work because the Javascript listener do not fire up correctly.
Any ideas how to make the listeners fire up?
Outcomes
