on(this.map.infoWindow, 'SelectionChange', lang.hitch(this, function() { var g = this.map.infoWindow.getSelectedFeature(); if (g) { var options = { graphic: g }; var cit = new ClipboardInfoTemplate(options, domConstruct.create("div")); cit.startup(); this.map.infoWindow.setContent(cit.domNode); } }));
Solved! Go to Solution.
have you tried console.dir(g) to output the complete feature? My guess is there is an attribute in there that will provide you with the layername
{ [functions]: , __proto__: { [functions]: , __proto__: { }, _graphicsLayer: null, _shape: null, _visible: true, declaredClass: "esri.Graphic", visible: true }, _graphicsLayer: null, _shape: null, _visible: true, attributes: { [functions]: , __proto__: { [functions]: , __proto__: null }, datalink: "value", dateposted: "2/22/2012", Intersection: "y", intid: "Value", measure: "2.0869", OBJECTID: "2", other: "Null", postedby: "kdl", RID: "8", Road: "Value", road2: "Value", SHAPE: "Point", studydate: "2/9/2012" }, declaredClass: "esri.Graphic", geometry: { }, infoTemplate: { [functions]: , -chains-: { }, __proto__: { }, _dateFormats: { }, _fieldLabels: { }, _fieldsMap: { }, chartTheme: null, declaredClass: "esri.dijit.PopupTemplate", info: { [functions]: , __proto__: { }, description: "OBJECTID = 2<br/>SHAPE = Point<br/>Road = Value<br/>Intersection = y<br/>road2 = Value<br/>other = Null<br/>studydate = 2/9/2012<br/>datalink = Value<br/>dateposted = 2/22/2012<br/>postedby = kdl<br/>measure = 2.0869<br/>intid = Value<br/>RID = 8<br/>", title: "KDOT Traffic Counts Intersections" } }, symbol: null, visible: true }
var attrs = content; //do some overrides var contentreplacement = SearchParams.resultContentOverride(attrs.content, result.layers, f); attrs.content = contentreplacement; //add some links attrs.links = links; //override title attrs.titleField = titleField; //modify content only in result table var fieldInfos = []; array.forEach(fieldNames, function(name) { fieldInfos.push({ fieldName: name, visible: true }); }); // alert(fieldInfos); var g = new esri.Graphic(f.geometry, sym, attrs); g.setInfoTemplate(new esri.dijit.PopupTemplate({ title: title, fieldInfos: fieldInfos }));
my recommendation would be to add the layer info to the attributes of the popup when you set itvar attrs = content; //do some overrides var contentreplacement = SearchParams.resultContentOverride(attrs.content, result.layers, f); attrs.content = contentreplacement; //add some links attrs.links = links; //override title attrs.titleField = titleField; //modify content only in result table var fieldInfos = []; array.forEach(fieldNames, function(name) { fieldInfos.push({ fieldName: name, visible: true }); }); // alert(fieldInfos); var g = new esri.Graphic(f.geometry, sym, attrs); g.setInfoTemplate(new esri.dijit.PopupTemplate({ title: title, fieldInfos: fieldInfos }));
