Geoprocessing Service Only Runs Once
510
06-01-2014 09:15 AM
MattTaraldsen
I am trying to publish an ArcGIS geoprocessing service in 10.2 I have a script setup that will run multiple times through Pycharm, but when I run it in ArcGIS it will run once and return this error:
  File "C:\Users\\Desktop\git\GeoprocessingService.py", line 477, in <module>
    main()
  File "C:\Users\Desktop\git\GeoprocessingService.py", line 372, in main
    cur)
  File "C:\Users\Desktop/git\GeoprocessingService.py", line 136, in value_query
    results = cur.fetchall()
  File "C:\Python27\ArcGIS10.2\lib\site-packages\psycopg2\extras.py", line 81, in fetchall
    res = super(DictCursorBase, self).fetchall()
  File "C:\Python27\ArcGIS10.2\Lib\decimal.py", line 543, in __new__
    m = _parser(value.strip())
TypeError: 'NoneType' object is not callable
Failed to execute (Script).
The script itself is 800 lines, but here is the query I have been running that errors out:
def value_query(id_field, id, value_fields, start_date, end_date, date_field, table, cur):
    query2 = "SELECT "
    for field in value_fields:
        query2 += "NULLIF({0}, '-999')::NUMERIC(6,2),".format(field)
    query2 += "{0} " \
            "FROM {1} " \
            "WHERE {2} = '{3}' AND {0} BETWEEN '{4}' AND '{5}' " \
            "ORDER BY {0} ASC;".format(date_field, table, id_field, id, start_date, end_date)
    #print "This is Query:"
    #print query
    arcpy.AddMessage("{0}".format(query2))
    cur.execute(query2)
    #print "These are value query results:\n\n {0}".format(results)
    return results
Like I said it runs once in ArcGIS then errors out. However, if I close Arc completely and run the exact same script again, it runs once then stops. I feel like there may be some sort of caching or something that Arc does, but am completely stumped.
IanMurray
This sounds something similar to what happened in my thread here.  If anything you have is running out of GDB, make sure you are usually a fully qualified pathname line (os.path.join etc etc).
I have no idea if that is possibly related or not.
