var symbol = new TextSymbol(); var renderer = new SimperRenderer(symbol); var labelLayer = new LabelLayer(); labelLayer.addFeatureLayer(map.graphics, renderer, "${TITLE}"); map.addLayer(labelLayer);
Solved! Go to Solution.
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no"> <title></title> <link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body, #map { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="//js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/geometry/Extent", "esri/layers/FeatureLayer", "esri/layers/GraphicsLayer", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/symbols/TextSymbol", "esri/renderers/SimpleRenderer", "esri/layers/LabelLayer", "esri/geometry/Polygon", "esri/InfoTemplate", "esri/graphic", "dojo/on", "esri/Color", "dojo/domReady!" ], function( Map, Extent, FeatureLayer, GraphicsLayer, SimpleLineSymbol, SimpleFillSymbol, TextSymbol, SimpleRenderer, LabelLayer, Polygon, InfoTemplate, Graphic, on, Color ) { map = new Map("map", { center: [-75.249, 38.485], zoom: 9, basemap: "gray" }); var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255,0,0]), 2),new Color([255,255,0,0.25]) ) var singleRingPolygon = new Polygon([[-75.77, 38.45], [-75.77, 38.7], [-75.11, 38.7], [-75.11, 38.45], [-75.77, 38.45]]) var attr = {"Area":"Southern Delaware"}; var infoTemplate = new InfoTemplate("Location","Area: ${Area}"); var gra = new Graphic(singleRingPolygon, sfs, attr, infoTemplate); graphicsLayer = new GraphicsLayer(); graphicsLayer.add(gra); map.addLayer(graphicsLayer); // create a text symbol to define the style of labels var textColor = new Color("#666"); var textLabel = new TextSymbol().setColor(textColor); textLabel.font.setSize("14pt"); textLabel.font.setFamily("arial"); textLabelRenderer = new SimpleRenderer(textLabel); var labels = new LabelLayer({ id: "labels" }); labels.addFeatureLayer(graphicsLayer, textLabelRenderer, "${Area}"); map.addLayer(labels); }); </script> </head> <body> <div id="map"></div> </body> </html>
Here is the code:
