How to find out what Extensions are Authorized on ArcGIS Server Machine
753
05-29-2014 01:52 PM
VijaySambandhan
I have an 10.0 ArcGIS Server Machine on which i will like to figure out if Network Analyst Extension for ArcGIS Server has been  Authorized or not for that machine.
Also if Network Analyst has been Authorized then I will like to remove the Authorization and authorize a different server.
I tried exploring the ArcGIS Server Manager site but could not figure it out.
Any ideas on how we can do this?
DishaGori
Hi Vijay,
On a windows install, you can open the keycodes file (default location: C:\ProgramFiles(x86)\ESRI\License 10.0 \sysgen) in notepad and if you see an entry for 'networkserver' , it indicates that you have the license for Network Analyst extension for Server.
To authorize it on a different machine, edit the file in notepad and delete the 'networkserver' line. Re-start the ArcGIS SOC and ArcGIS Server Object Manager service from windows services. You should then be able to use that authorization number to authorize it on a different machine.
DishaGori
Hi Vijay,
VijaySambandhan
That's exactly what I needed.
Thank you!
