AnsweredAssumed Answered
Switch statement JS
Question asked by alex92190 on May 27, 2014
Latest reply on Jun 9, 2014 by alex92190
Hi all,
I am trying to create a GIS data portal that allows users to select one out three diffent methods for data extraction.
1) extract by graphic extent
2) extract by extent of a county
3) extract by unit (calfire)
Here is my problem. I am using a switch statement that allow the users to select either one of these methods independently as shown on this thread.
However, when I trigger the either one of the cases within my function by pushing on a download button. It seems like the GPtool cant access any input data for some reasons.
errors I get for each of the functions described above :
TypeError: Unable to get property 'geometry' of undefined or null reference  TypeError: Unable to get property 'style' of undefined or null reference  TypeError: Unable to get property 'style' of undefined or null reference
My code:
var extractMethod = "extractByPoly";    var extractMethod = "extractByCounty";    var extractMethod = "extractByUnit";        function myFunction() {     //var extractMethod = "extractByPoly";     //var extractMethod = "extractByCounty";     //var extractMethod = "extractByUnit";      switch (extractMethod) {         default:              //function extractData() {             //get clip layers             var clipLayers = [];             if (registry.byId("layer1").get("checked")) {                 clipLayers.push("SRA");             }             if (registry.byId("layer2").get("checked")) {                 clipLayers.push("Burn");             }             if (clipLayers.length === 0 || map.graphics.graphics.length === 0) {                 alert("Select layers to extract and draw an area of interest.");                 return;             }              var featureSet = new FeatureSet();             var features = [];             features.push(map.graphics.graphics[0]);             featureSet.features = features;              var params3 = {                 "Layers_to_Clip": clipLayers,                 "Area_of_Interest": featureSet,                 "Feature_Format": registry.byId("formatBox").get("value")             };              domStyle.set(loading2, "display", "inline-block");             gp.submitJob(params3, completeCallback, statusCallback2, function (error) {                 alert(error);                 domStyle.set(loading2, "display", "none");             });             //}             break;          case "extractByCounty":             //function executeQueryTask(county) {             var clipLayers = [];             if (registry.byId("layer1").get("checked")) {                 clipLayers.push("SRA");             }             if (registry.byId("layer2").get("checked")) {                 clipLayers.push("Burn");             }             if (clipLayers.length === 0) {                 alert("No layers to clip, please select a layer you would like to clip...");                 return;             }              var county = document.getElementById("sel_county").value             var unit = document.getElementById("sel_unit").value             var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Counties/MapServer/0");                                       var query = new Query();             query.returnGeometry = true;             query.outFields = ["NAME_PCASE"];             query.where = "NAME_PCASE = '" + county + "'";             query.outSpatialReference = map.spatialReference;             queryTask.execute(query, function (featureSet) {                 var AOI = featureSet.features[0].geometry;                 var graphic = new Graphic(AOI);                 var features = [];                 features.push(graphic);                 var fSet = new FeatureSet();                 fSet.features = features;                   var params = {                     "Layers_to_Clip": clipLayers,                     "Area_of_Interest": fSet,                     "Feature_Format": registry.byId("formatBox").get("value")                 };                    domStyle.set(loading, "display", "inline-block");                 gp.submitJob(params, completeCallback, statusCallback, function (error) {                     alert(error);                     domStyle.set(loading, "display", "none");                 });             });             //}             break;           case "extractByUnit":             //function executeQueryTask1(unit) {             var clipLayers = [];             if (registry.byId("layer1").get("checked")) {                 clipLayers.push("SRA");             }             if (registry.byId("layer2").get("checked")) {                 clipLayers.push("Burn");             }             if (clipLayers.length === 0) {                 alert("No layers to clip, please select a layer you would like to clip...");                 return;             }              var unit = document.getElementById("sel_unit").value             var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/Alex_Try/Layers/MapServer/1");                          var query = new Query();             query.returnGeometry = true;             query.outFields = ["UNITCODE"];             query.where = "UNITCODE = '" + unit + "'";             query.outSpatialReference = map.spatialReference;             queryTask.execute(query, function (featureSet) {                 var AOI = featureSet.features[0].geometry;                 var graphic = new Graphic(AOI);                 var features = [];                 features.push(graphic);                 var fSet = new FeatureSet();                 fSet.features = features;                   var params2 = {                     "Layers_to_Clip": clipLayers,                     "Area_of_Interest": fSet,                     "Feature_Format": registry.byId("formatBox").get("value")                 };                    domStyle.set(loading1, "display", "inline-block");                 gp.submitJob(params2, completeCallback, statusCallback1, function (error) {                     alert(error);                     domStyle.set(loading1, "display", "none");                 });             });             //}     } }
Any idea why I get these errors?
Outcomes
