Sync offline edits ignored
2908
05-22-2014 02:27 PM
AlexanderLitvak
I was able to download a local geodatabase replica, but when attempting to execute Sync method to download/upload changes nothing is happen, neither Status block or Completion block is executed.
I've performed local changes and Server side changes still nothing....
Used example from here: https://developers.arcgis.com/ios/guide/sync-offline-edits.htm
Downloaded data is include (.geodatabase, .geodatabase-shm, .geodatabase-wal )
Service configuration is:
Sync Capabilities:
Supports Registering Existing Data: true
Supports Sync Direction Control: true
Supports PerLayer Sync: true
Supports PerReplica Sync: false
Supports RollbackOnFailure : false
Supports Async: true
Alex
AlexanderLitvak
This is resolved, the provided code was correct, just some weird behaviour when binding native from C# layer.
Thanks for help!
NimeshJarecha
Please attach a sample application you wrote. Also, try using this sample and see it works for you.
Regards,
Nimesh
AlexanderLitvak
Hi Nimesh,
I have runed the ESRI sample and it works.
Please find attached my code.
Alex
AlexanderLitvak
Thanks for help!
