Using the Large Map Zoom Slider in Compact Build
916
05-22-2014 10:31 AM
KenDoman
Occasional Contributor II
For my application, I'm modifying the map's large zoom slider to create a custom look. However, if I use the compact build of the library (for certain other reasons), the map loads with the default smaller zoom tool. In the map options, setting sliderStyle: "large" doesn't matter.
Is there a way to force the compact build to load the larger zoom slider?
