meewasinvalley
Transformation from WGS1984, EGM96 Global to NAD 1983
Discussion created by meewasinvalley on May 22, 2014
Latest reply on May 23, 2014 by meewasinvalley
I am trying to find the correct transformation to convert a shapefile in WGS 1984, EGM96 Global into NAD 1983 UTM Zone 13N.
I am not very familiar with WGS 1984 and EGM96 Global. Can I still use the NAD_183_To_WGS_1984_7 transformation (this is for Saskatchewan, Canada)? My projection is not defined when I bring it into ArcGIS 10.2.1. Can I just use the WGS 1984 projection?
Will my elevation data still be correct?
Thank you for your help in advance.
Outcomes
