kuit
Limit in number of composite locators?
Discussion created by kuit on May 22, 2014
I am trying to put together a group of 8-9 address locators in a composite locator. Two are from another organization which I can not recreate and includes a composite of two.  All of them work individually.  I have put them in the same directory, tried shapefiles and file GDB on the ones I create.  I've projected them to be the same.
I can use the two from the other organization and add three more that I've created and it works fine.  When I try to add another, I get the message "There was an error trying to process this table" - as soon I hit the OK in the geocode interface.  It does not even start processing.  I've tried adding different combination to see if an individual locator was the problem.
The interesting thing is that I combined all of them once but mixed up the order where the large USA street one was towards the end and it would work.
On-line it says it is possible to combine up to 30 locators, but does not recommend any more than 10.
Does anyone know of any other limits I might be bumping in to?
Thanks!
Outcomes
