http://tiledbasemaps.arcgis.com services not storing credential when added to Portal
821
05-15-2014 07:39 AM
Yi-SzLin
Even I chose Store credentials with service item and Do not prompt for authentication when adding the tiled basemap to portal for offline editing in collector, it prompted me to enter credentials everytime. Please help.
Yi
RussRoberts
Esri Notable Contributor
Are you getting prompted in the Portal multiple times when you load a map with the tiledbasemaps layer as a basemap?
Russ
Yi-SzLin
Yes.
Yi
RussRoberts
I would recomend posting this issue into the Portal for ArcGIS forum here: http://forums.arcgis.com/forums/256-Portal-for-ArcGIS
by Anonymous User
Not applicable
Hi
I am trying to add tiledbasemap service in portal as an item but unable to do so, please help?? username and password is always failing and i don't know why , portal and AGO both are SSO using AD and Azure AD respectively
I have to setup this basemap for offline editing use for collector app
BR
