Hi all... I'm trying to produce a map type "density of points". I need the output to be: number of observations (points) per square kilometer.
I've done tests with Point Density utility, but I don't understand the pixel value in the raster calculated.
Can anyone tell me how to adjust in the input parameters for the output to be in number of observations per square Kilometer.
The source points feature class is in UTM 30N Meters. Each observation (point) counts as 1, so I put NONE in field population.
Thanks in advance
