Hi allwhen I try to add a grpahic to my map I get the following error message:function showResults(results) {
//symbology for graphics
var markerSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25]));
var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 1);
var polygonSymbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NONE, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASHDOT, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]));
//find results return an array of findResult.
if (map.graphics) {
map.graphics.clear();
// var dataForGrid = [];
var g;
//Build an array of attribute information and add each found graphic to the map
dojo.forEach(results, function (result) {
var graphic = result.feature;
// dataForGrid.push([result.layerName, result.foundFieldName, result.value]);
switch (graphic.geometry.type) {
case "point":
graphic.setSymbol(markerSymbol);
break;
case "polyline":
graphic.setSymbol(lineSymbol);
break;
case "polygon":
graphic.setSymbol(polygonSymbol);
break;
g = graphic;
var zoom2 = 0.08;
map.centerAndZoom(g.geometry, zoom2);
map.graphics.add(g);
