<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Map with legend</title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 97%; width: 98%; margin: 1%; } #rightPane { width: 20%; } </style> <script src="//ajax.googleapis.com/ajax/libs/jquery/1.11.0/jquery.min.js"></script> <script src="http://js.arcgis.com/3.9/"></script> <script> var map; require([ "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Legend", "dojo/_base/array", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "dojo/domReady!" ], function( Map, FeatureLayer, Legend, arrayUtils, parser ) { parser.parse(); map = new Map("map", { basemap:"topo", center: [-96.53, 38.374], zoom: 13 }); //add the legend map.on("layers-add-result", function (evt) { var layerInfo = arrayUtils.map(evt.layers, function (layer, index) { return {layer:layer.layer, title:layer.layer.name}; }); if (layerInfo.length > 0) { var legendDijit = new Legend({ map: map, layerInfos: layerInfo }, "legendDiv"); legendDijit.startup(); } }); $.get("https://maps2.petroweb.com/MAPS2ArcGISServer/tokens?request=getToken&username=pwuser&password=Mauser$98K&expiration=1440&client=http%20referer&referer=localhost") .done(function (data) { var imageParameters = new esri.layers.ImageParameters(); imageParameters.format = "png"; var mapServiceURL = "http://mymapserver.com/MAPS2ArcGISServer/rest/services/MySecureService/MapServer/?token=" + data; //var mapServiceURL = "http://mymapserver.com/MAPS2ArcGISServer/rest/services/MyUnsecureService/MapServer/?token=" + data; var usWellsLayer = new esri.layers.ArcGISDynamicMapServiceLayer(mapServiceURL, { "opacity": 1, "imageParameters": imageParameters }); map.addLayers([usWellsLayer]); }) .fail(function (xhr, textStatus, errorThrown) { alert("Failed to get us wells map layer security token."); }); //map.addLayers([colorado]); }); </script> </head> <body class="claro"> <div id="content" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width: 100%; height: 100%; margin: 0;"> <div id="rightPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'"> <div id="legendDiv"></div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" style="overflow:hidden;"> </div> </div> </body> </html>
Solved! Go to Solution.
var layer = new Dynamic('http://some_url/some_service?token=some_token', { //options }); layer.url = 'http://some_url/some_service'; map.addLayer(layer);
