Solved! Go to Solution.
Hello Jian,
I think you can use arcpy.Select_analysis the same as arcpy.FeatureClassToFeatureClass_conversion and arcpy.CopyFeatures_management. Just don't specify a where statement and it will export all records in the input feature layer.
I don't think it would be any faster than arcpy.FeatureClassToFeatureClass_conversion or arcpy.CopyFeatures_management, but it might be worth a try.
