TAIP0xF0 DeviceId
2424
7
04-30-2014 10:13 AM
AnanthPalani
I am using TAIP adapter to process Sierra Wireless GX440 modem TAIP RPV messages. When I see the text output I do not see the DeviceId. Does the adapter parse DeviceId?
AP
RJSunderman
Hello Ananth -
Yes, looking at the TAIP0xF0 GeoEvent Definition, the DeviceId is being retrieved from the event payload by the adapter. In fact it is being used as the TRACK_ID.
What output are you using to review the event data? Are you receiving the other fields (TimeStamp, Shape, Speed, Heading, Source, and Age)?
- RJ
AnanthPalani
Thanks RJ for a quick response. I am using tcp-text-out and I see Time, Lat, Lon, Speed, Heading, Source, Age but not deviceId.
Best Regards
AP
RJSunderman
Ananth -
Thank you for the sample TAIP / RVP data and references you sent. It appears that the SierraWireless mobile gateway configuration utility - the "ACE Manager" - allows an optional TAIP ID to be specified on its GPS page.
We will see what we can do to to extend the sample TAIP conector to: 1) Determine if this parameter has been included in the broadcast data; 2) Place the TAIP ID, if found, into the DeviceId field of the GeoEvent as a String.
I will follow-up with you as soon as possible. Thank you in advance for your patience.
- RJ
VladislavPlechnoy
New Contributor III
Ananth,
I have a build of Trimble TAIP Adapter bundle for GeoEvent Processor enhanced with DeviceID reported from the modem.
Please find it attached to this post.
I would like you to field-test this update for us and provide a feedback if enhancement works as expected.
I will then update our public forum page and GitHub repository with related changes.
Vlad.
AnanthPalani
Vlad & RJ
Thanks for a quick turnaround. It works. I see the Vehicle ID we configured coming in.
Thanks again
Best Regards
AP
VladislavPlechnoy
New Contributor III
Ananth,
Please keep us posted if you discover any issues as you are field-testing TAIP adapter.
Your feedback is highly appreciated.
Vlad.
AnanthPalani
Sure will do. Thank you all.
Best Regards
AP
